RSLinx 2.57 Devicenet driver
WTFSUNELECSUP
Jan 2014
Alberta
63
I installed RSLinx 2.57 on a new laptop today and need to access the 1771-SPDNT driver, and I can't find it listed under the add new, or config drivers, only the first 6 drivers appear in the window.
Am I missing something? as I can't see any of the Dnet drivers,
Please let me know what i'm doing wrong
Which operating system are you running, and is it 32-bit or 64-bit ?
At some point a few years ago (and that version of RSLinx is 5 or 6 years old) the DeviceNet subsystem wouldn't work with a specific mix of Windows operating systems and versions of RSLinx Classic.
I did find a Knowledgebase document that suggested that RSLinx Classic 3.50 or higher is needed to run the DeviceNet Passthrough drivers in a Windows 7 64-bit environment.
WTFSUNELECSUP said:
I installed RSLinx 2.57 on a new laptop today...
That's what I was wondering...what OS are you running?
Was it this you read Ken?
17425 - 1747-SDN and 1771-SDN Pass Through Setup Requirements
I'd suspect the same. I have RSLinx Classic running natively in Win7x64 as well as in XP in VMware. Those drivers are not available for me in Win7x64, but are in XP.
G.
Hi I'm new to Allen Bradly. I've managed to uploaded the PLC code, but need to diagnose the devicenet card. How do I upload the configuration so I...
1,844
I am running into some trouble trying to get some old Allen Bradley DTAMs to communicate with a ControlLogix 1756-DNB module. I am hoping someone...
4,468
Have anyone met this issue that you cannot see the devicenet scanner via RSlinx or RSnetworx? I am using 1769 SDN @ node 1 on compactlogix. For...
11,239
I recently separated the office network from the Plant network with a firewall and my PC is on the office side. I have to VPN into the plant...
3,712
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
192
