Rslinx Classic Gateway License
bornwild
May 2010
Riyadh
429
Hello all,
We purchased rslinx gateway license. Rockwell sent me a link to download the software as well product key and serial number. I downloaded from the link and installed the set up but I have dont any factory talk activation and my rslinx status shows I am using gateway (NOT OEM) which is good. Is it already activated.? Do I need to do the activation? The pc is quite old windows xp 32 bit .
RSLinx Classic will run with its full capabilities under the same unlicensed "grace period" feature as other products like FactoryTalk View Studio or Studio 5000 Logix Designer.
Those other products use a pop-up to remind you that they have not been activated and how long you have until the "grace period" expires.
RSLinx does not use that pop-up. Instead, it just runs in Grace Period for 7 days, after which it will return to running as RSLinx Lite.
You can test this by simply waiting.
Thanks a lot. I never knew this. For other softwares like rslogix it shows evaluation running. This is weird from rockwell
Inexperienced user here. We are upgrading servers and currently have RSLinx Classic Lite with a dozen SLC505s on it. The new server will run FT...
814
I am not able to configure drivers in RSLinx classic gateway,can anyone suggest what could be the possible reason and a solution for the problem...
1,808
Hi ppl, im new here, i have some question. I need to imports tags from rslogix 5000 to an excel file. I know that is easy when you have RSLINX...
3,334
I am having and error thrown by RSLinx on the Event Viewer: a DDE/OPC client has passed an invalid server handle while attempting an Async IO...
3,050
Hi, In my Computer, I already have Rslinx Classic gateway version to connect to PLC online by RSligix 5,500,5000. For another reason, I need...
8,806
