RSLinx OPC Server + MS Excel Question
arth608
Jul 2017
Auburn Hills
Hello All,
I know it is possibile to access data from a PLC directly to excel using a OPC link through RSLinx. https://www.youtube.com/watch?v=pERxjWUaRUI
Question: Once the data is in excel and continuously being updated, is it possible to automatically export it at a specific time interval? (i.e. every 15 mins) If yes, how can I go about achieving this?
Question 2: If the above is possible, can I also export in a XML format at all?
Thank you and please let me know if there are any questions.
Hello All,
My first initial thought would be to write a script to handle that automation. A few common scripting languages come to mind, but I would probably use Python, as there are most likely ready-made, easy to use methods in one of the Python libraries to handle those automation tasks.
Excel to XML using Python
File Handling using Python
Never tried it but you could generate the XML in VBA here is a link, I have not looked at it closely & I'm sure there are plenty of others if you search.
https://www.tek-tips.com/faqs.cfm?fid=7736
On the 15 minute log, perhaps rather than enabling/disabling the OPC you could again in VBA create a 15 min timer & then every time it triggers run the XML code to save the file.
Here is some code :
Dim nextTriggerTime As Date
Private Sub UserForm_Initialize()
ScheduleNextTrigger
End Sub
Private Sub UserForm_Terminate()
Application.OnTime nextTriggerTime, "modUserformTimer.OnTimer", Schedule:=False
End Sub
Private Sub ScheduleNextTrigger()
nextTriggerTime = Now + TimeValue("00:15:00")
End Sub
Public Sub OnTimer()
''//... Trigger whatever you want here
''//Then schedule it to run again
ScheduleNextTrigger
End Sub
''// Now the code in the modUserformTimer module
MyUserForm.OnTimer
Hello All, I am going to try and lay out my situation as good as I can. Scenario: We have sites in different location across US that's running...
2,952
Hey! In my previous queries on how to handle an OPC server like RSLinx in the ArchestrA IDE galaxy, I have succeeded and the answer was to just...
1,821
Hey everyone!. I would like to know how to use a third-party data server other than Wonderware, such as RSLinx server to integrate it into the...
1,581
Hi Experts, I am using Matlab as an OPC DA Client to communicate with AB PLC rslogix5560. I can successfuly read from the PLC but when i try to...
1,562
Hello PLC expert i need your help. i want to use OPC communication and Matlab to read and write data from/to a Logix5561. A Topic is...
1,652
