RsLinx or ABCIP DA server
phil hughes
May 2005
31
We presently have a Wonderware application using RS LINX PRO /opc dde communicating via a 1761 NET ENI module to a compact logix L30 processor. We have communication errors occasionally, wondering if we would be more efficient using wonderware's ABCIP DA Server?
RSLinx is very good at what it does, but it is not the most efficient opc server around.
Most people opt for a third-party solution, they are usually better optimised for data transfers.
I do not know the ABCIP DA server you mention, but that is just one choice of many, google "allen-bradley opc servers".
If you are using the WW FSGateway to communicate with RSLinx OPC, then you effectively have 3x communication transactions happening, 1 from RSLinx to the PLC, 1 from FSGateway to RSLinx OPC, then WW Suitelink to FSGateway.
By using the DASABCIP server, you will eliminate the need to communicate via OPC, as the DASABCIP server communicates directly to the PLC.
Plus, by using the DAS server, is one less application to manage :cool:
You may need to look at tag scan times and quantity of tags. Also read all the fine details in the 1761-NET-ENI manual on it's limitations. It has limited number of available connections. If you have a couple of HMI's and other stuff it could be overloading the module and serial port, especially if you go online to program with RSLogix.
Darren
I don't have a whole lot of experience with RSLinx Enterprise or I guess it's also called FactoryTalk Linx. We have a Rockwell FTView SE based...
59
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
84
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
234
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
279
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
198
