RSLinx - TCP Settings (maybe?)
Kidblue
May 2003
Worcester
698
Hello,
Could anyone please clarify or confirm whether RSLinx (single node in this case) needs any ports opening or authorising, if used via some form of router/switch?
Below is a question asked by our customer in preperation for us modifying his machine network and company intranet....
The router in place is already filtering some of the network traffic out, although we need to investigate further when all the office staff and their PCs are fully operational on Monday.
In order to configure the firewall and filtering properly on the router, we need to know what kind of traffic RSLinx runs between the PLC and its "own PC". For example, is it UDP on port 30, HTTP on port 80 or something completely exclusive to RSLinx ?
I have tried to find out what it is by turning RSLinx on this morning, and looking at our firewall logs, but it is not recording anything at all.
Once I know what it is, then I can set the router to block all other incoming traffic from the rest of the network (except you, when you dial
in!)
What we're basically trying to achieve is an SLC 5/05 talking to a PV+1000, with a single PC running Linx and Access only, sitting on it's own IP range (192.168) and then this is connected via a router to their intranet to view and manage the Access database (using .asp) on a different range (132.147).
I would of thought that as long as the PLC can see the local PC, then he only needs to ensure that his intranet can then see the same PC (leaving Linx alone)....
The only reference i could find when googling referred to TCP 516, but nothing else (and i know i've never had to open ports before for Linx)
Thanks.
Check KB 29402 - it shows all port used
Technically you need 2222 and 44818
In some cases Ethernet/IP driver will not work and Ethernet Devices should be used
Hi everyone, I have a customer that is using wireless modem to communicate to many different PLC's and HMI's. I just added my PLC and HMI to...
3,897
I've personally never used DDE thru RSlinx. I'd like to create a VB macro that imports values from a txt file integer to act as data transmissions...
3,198
I don't have a whole lot of experience with RSLinx Enterprise or I guess it's also called FactoryTalk Linx. We have a Rockwell FTView SE based...
27
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
69
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
226
