Rslinx Trouble
ravi1821
Dec 2003
klang,selangor ,malaysia
24
Dear sir,
Currently i am working with a new modification job which using allen bradley cpu slc 500 type 1747 - L40C. When i started up the rslink it promps me the Message " Fatal Error Initializing PIC Device driver ". After that i click OK button the at the communication menu i configure the driver 1747-PIC/AIC. After that i add the driver it doesnot goes to running mode. Anybody can
advise me on this matter
Thanks in advance.
Ravi Chandran
What kind of computer are you using desktop or laptop. Does it have a real serial port. ( it must have a real serial port to work).
pls check is it showing device (miniature of slc ) in rslinx
u stop and then remove any other drive which is using the same communication port like com1 com2 ...
try with some other node addresses
Do you have RSView installed, if so RS Linx will be running as a service and you need to go to RSLINX CLASSIC LAUNCH CONTROL and tell it not to run as a service.
RSLINX trouble
dear sirs,
Thank you for your valuable comment in my earlier query. The problem is that my laptop doesnot have a real serial port for me do the communication with PIC device.
Further to this, i have installed the rslogic and rslink my desktop pc and since i have only 1 license key. I had to move the key from my laptop to the master floppy disk via MOVE ACTIVATION 32 BIT but another problem occurs. The master disk which i used earlier to transfer the key to my laptop seems not working now. It gives could not activation file in floppy disk and the license key still present in my laptop.
Any advise guys.
Thanks in advance
Ravi Chandran
You need the 1747-UIC. It is the USB version of the 1747-PIC.
Make sure RsLinx is shut down before you move the activation. Do a screen capture of your error
ravi1821 said:
dear sirs,
Any advise guys.
Thanks in advance
Ravi Chandran
You should be able to leave the activation installed on the laptop and just install RSLinx Lite on the desktop. As long as you are only connecting to a single node and not using OPC or DDE this should work.
It is possible to run RSLogix and Linx on your desktop by just installing the master disc, without relocating the licence, just boot up logix while the disc is in.
Sounds like your disc is stuffed, as long as your supoprot is current it won't be a problem to get a new diosc out of Rockwell.
Cheers
I'm needing some help with a project that I'm finishing up. I have just replaced an older versaview 1500p with a new solid state hard drive 1500p...
1,752
Hello, I have been experiencing some problems with one of our PLC Programing Terminal. We recently installed a CLX Gateway for use with our DH...
1,953
So the laptop I was using to troubleshoot our system was on the way out and now I have all the software installed on a newer machine. Moved my...
1,470
Hi, I'm using RSlinx ver 2.20.1 but I'm having trouble with it. When I open it I click on the choose driver (I'm using DF1 to communicate with a...
5,120
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
197
