kolyur
I would recommend using the cascaded counters method that was suggested earlier, then using a formula tag in Crimson to combine the two values into one. This would save you from having to display two integer values right next to each other.
For example, if you have two counters X and Y and the first one (X) resets at 1000 and increments Y by one, your formula would be: (1000*Y)+X.
