Slc 500 And Rslogic
Not exactly sure what utility you are referring to.
Just so you know:
  • RSLogix is Windows based software on your PC used to create an application to be compiled and downloaded into your SLC 500
  • AI500 is DOS based software also used to create an application to be compiled and downloaded to your SLC 500
  • The SLC 500 doesn't care which was used. Once it is in the SLC it is software independent.
  • RSLogix can open and use programs written in AI500. No utility or converter is necessary.
So, can you clarify what it is that you are trying to accomplish? Please forgive the notes above if you already know all that. Just trying to be sure we are on the same page.
OG
we are trying to get into a SLC500 1747-l20c with rslogics 500 we get the error "decompiler unknown error" half way though the upload I read on here that some programs created and uploaded with the old ICOM software can not be opened with the new rslogics and that there is a utility called AI500 ???
I have seen a similar error in the past when I was using an older version of rslogix than what was used for the last download to plc
Derek
I have a program that I've used 100 times. SQO settings: File N7:0, Mask 0FFFFh, Dest B3:1, Control R6:0, Length 8, Pos 2. Length & Position...
48
979
Everyone, i am in the process of purchasing the Slc 500 version of software to support what we have and i have a question. Several of our...
775
In a slc 500 plc I am trying to move data with out using a lot of moves. I want to move data from n7:1 to n7:2 and data that was in n7:2 to n7:3...
1,368
Customer has a circa 2004 SLC-500 PLC. Fieldbus is a 1747-SDN DeviceNet scanner. Customer has SLC-500 file (.rss) with no comments. Has no *.dnt...
565
After I tried wiring, I used computer program communication to read the PLC N value, but received a NAK signal. And the DL3500 CHA light keeps...
432
