RSLogic 5000
Terry Boblitt
Jan 2006
Willisburg, Ky.
119
I've got more experience with RSLogic 500. With that being said-I need to install 5 TON timers. I need to do this on line if possible?
I know I need to create a tag to that timer. Went to a class back in December--just need to get someone to jog my brain. Need to get on the right track.
Thanks to all
Terry
Go online. Insert your new timer instruction into the program and give it a tag name. Now right click on the tag name and select New "tagname" and a dialog box will appear for a new tag of type timer. Set the scope, add any comment you want, and click OK. Now you can set the preset for the timer, and accept and assemble edits when you are done.
Don't forget that all RSL5000 timers are in milliseconds. RSL500 lets you choose which timebase to use. Don't forget to "scale up". That's the biggest change in the timer scheme, to me at least.
I knew it was something simple. Just need to put in 5 rungs at different locations and have a bit to turn on the timer. Going from RS500 to RS5000 is different and I'm trying to adapt. If you don't do it on a day to day basis you don't really forget--gust miss a step.ha ha
Thanks to ALL
Terry
Hye Does anyone here have the V17 copy. Mind to share? I downloaded but got error during install.
1,860
Hi All, I have compact logix L32 PLC and I want to establish connection between Festo CPX-F32 Valve Island over Ethernet I/P network. The Festo...
2,386
hi guys i have a force light on our compactlogix, i have looked in the plc ladder program and can not see any forces, i have looked at the...
24,264
hi guys i have a question, i have created a program tag name in rslogix 5000 which i dont need to use but i dont know how delete . can anyone help...
3,319
Looking for info on converting RSLogix 500 file to RSLogix 5000 format. 1747-L552 CPU is being changed out with the 1769L35E
9,814
