rslogic500
judahboxing
Aug 2005
ontario
Hi to all and have a good day.
I am trying to install my RS logix 500, RS Lite and finally tranfer the activation key from master diskete to drive C:. The software works.
My problem is when i try to move the activation key from drive a: to a c:( using the master disk) a problem occur and A message is display on the screen and I quote "file not found". You know what happen the activation key was lost?. My question is how can I obtain activation key without buying another set of software? Can I reset the master disk(activation key)? How? Please advice I need the software very badly. We are shut down.
Many thanks,
judah
If you call Rockwell they will reset the activation for you.
Or you can just leave the floppy in the A drive and it will run the program.
Regards Alan Case
Dear all how to hide file menu + toolbar panel in rslogic500? I've seen other people use shortcut keys to hide and unhide. But I forgot how to...
349
Hy again, Does anybody knows how to export some tag values from rslogix 500 to a .txt file ( excel, notepad, etc ) in real time ? i whant to...
3,669
We have RSLogic500. We were told that we had to run Windows XP Pro for it to work. We upgraded our laptop from Home version to Pro. When I go to...
2,478
i need to display machine run time, i was looking for some canned logic for a run hour meter. rslogic 500 to pv 550.
10,358
i have worked with rslogic 500ab.i started a new job they have controllogic 5000,is it similar 500 and how do they compare.i had my first look at...
23
10,441
