RSLogix 500 Analog Output Maximum
pct_jimmy
Dec 2006
Shady Spring, WV
61
Its been a while since I've programmed a SLC and I'm a little stumped about trying to find an easy way to do this. I am running a SLC 5/04 with a 1746-NIO4I analog IO module and I need to limit the maximum value of the output. The input is a pot switch and there is a selector switch that is intended to limit the maximum speed produced by a hydraulic valve/motor combo (position 1 is a lower speed, position 2 will allow a little faster).
I know there's a simple way to do this but I'm trying to get out of my foggy RSLogix 5000 programming ways and go backwards a little bit.
Any help is appreciated.
Wherever you are moving the data into the AO integer output simply have a greater than X move X into the output integer rung.
Hello all. I have been working with an SLC 5/04 system, which houses various Digital and Analog INs and OUTs, up to Slot 29. I am currently...
2,522
Hello guys, Hopefully a simple one for you but I can't seem to find the answer listed in Rockwell's literature...
2,729
G'day lads, We are using an Allen Bradley PLC slc5/03 with an analog input module 1746 ni4. we have a sensor with a response rate of 250ms. in...
3,137
I've got a slc 5/03 and the 1746-FIO4V card= 2 Input (V or mA) and 2 output (0-10 vdc) and am setting up an analog output in RSLogix. If so, I...
9,619
hi! can anyone describe how addresing analog inputs in ladder diagram for RsLogix 500 and which symbol use?? i am new in RsLogix, till now i was...
7,809
