RSLogix 500 hangs when going on-line
rguimond
Jul 2009
Escuminac
666
Recently, our copy of RSLogix 500 began acting strangely. It opens fine, but when a processor is selected to go on-line, we get an error message that says |RSLogix has encountered and error...". What's really strange is that it occassionally doesnt happen. BTW, we're using RSLinx Gateway on another PC and have TCP driver set up on the PC with the proble. Worked fine until last week?. Any suggestions?
We have a problem like this occassionally. I don't know what the cause is, but if you open RSLinx and delete all your drivers, it will start working in RSLogix. You then have to add all your drivers back.
may i suggest the following:
use the rslinx backup utility to backup your settings while the pc is working fine.
when rslinx crashes, delete your drivers and restart rslinx.
then restore your drivers using the restore utility.
if it works, great, if it doesn't then rebuild your rslinx config file.
regards,
james
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
87
I have a little bit of experience with Allen-Bradley. I have a Micrologix 1500 (RSLogix 500) and a PanelView Plus 7 (FactoryTalk View Studio ME)...
168
buen dia. tengo una falla al pasar los tags de mi plc SLC 5 0/4 a mi panel me aparece un error Problem writing value " " to item <tag name>...
83
Will someone please convert this logic to pdf?
127
Hello, Haven't been on in a while. I need to generate a bit level pdf of the I/O for RSLogix 500. I can generate a report but it just shows the...
162
