RSlogix 500 no print report option
Thunderbike
Jan 2014
New York
good morning. I am currently updating a machine that was built a bazillion yrs ago with an SLC 5/04. It wasn't bad enough to find that the company that built this one off machine (long out of business) put NO descriptions anywhere on the 150+ rungs, but the "print report" option is gray and not functioning. I've tried changing the options, even turning on just one or two, and it is still not alwaying me to use it.Im using a legit purchased version of RSLogix 500 Standard, am I missing something? I would like to print the program so that I can try to work to identify addresses and add descriptions so that I can find the rungs I need to modify, as I don't even have a wiring diagram and there are two racks with 8 slots filled.
Thanks,
brett
Are you on line with the processor while trying to print? I'm pretty sure you can't do that.
I'm pretty sure that Doug-P is right - you must be OFFLINE in order to use the Report/Print feature ...
just a tip:
search DILIGENTLY/DESPERATELY for a backup copy of the RSS file on a floppy disk, etc. ... just to make sure that you realize this: the comments and descriptions MIGHT have indeed been entered - but that type of documentation is NEVER present inside the SLC-500 processor ... if you can find the RSS file, your problems might suddenly become substantially less worrisome ...
also ...
if the program was written about one-and-a-half bazillion years ago, the program file MIGHT have an extension of ACH ... keep your eyes open for that file extension too while you're searching ...
and a LOOOOONG shot: check under "Options" in RSLogix500 and make sure that the rung and instruction comments are actually turned ON ...
Will someone please convert this logic to pdf?
127
Can someone give me a printout of this file? Could not find the standing thread for this...
1,410
Hello everyone i am working with rslogix 500 software and need to print a report which is no problem, but i want to also do it in a pdf format, is...
3,001
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
87
I have a little bit of experience with Allen-Bradley. I have a Micrologix 1500 (RSLogix 500) and a PanelView Plus 7 (FactoryTalk View Studio ME)...
168
