RSLogix 500 Programming Help
bfranklin
Sep 2012
Alberta
125
Hey,
I have pump running off a vfd that controls level in a tank.
Now the client wants to have a progressive low flow setpoint meaning the low flow set points should about 10% of what the current flow is.
I have the logic working good for when the pump flow climbs by having the current flow in a limit block and if the current flow is in between the hi and low limits it takes 10% of the current flow and puts that into the low flow alarm setpoint.If the flow goes above a certain value it unlatches the first alarm sequence logic i just mentioned above and latches the next sequence but with a higher flow rate and limits.
Now how do I go about this when the vfd slows down?
how about just always setting your low flow based on 10% less than the command vfd speed output?
Hi guys , I know there is so many was to program plc, I'm after the best way to stop an output double triggering, I was working on a machine last...
2,058
Hello everyone, Please forgive my ignorance, but I am new to the field of PLC programming. I would like to know if RSLogix 500 could be used to...
10,864
Rockwell Allen Bradley Programming Software, RSLogix 5, RSLogix 500, RS Linx, RSLogix 5000, version 2007, 1 DVD ----------------------- The old...
21
86,667
Please help to find the documents for programming RSLogix 500 for AB/SLC 500 on the net. I am new in this product so any information will be big...
9,844
Hi, I'm writing a program Yokogawa PLC. Due to the, Yokogawa software is not able to do stimulation, thus I'm writing the program using RSLogix...
7,680
