RSLogix 500 RS0AUT32.dll fault
Scorch Draken
May 2016
Houston, Texas
I am needing help with an issue that I am having with my RSLogix 500.
I have freshly installed it on a new laptop, and have already fixed a problem for RSWL032.dll faulting out. Now I have a new fault with RS0AUT32.dll in my RLogix 500 folder. It also tells me in an error window that the language resource file has stopped working and gives me a set of log files that describe the issue. The information from the file that has information in it will be at the end of this post.
My specs are as follows.
Windows 7 64-bit
RSLogix 500 version 5.20
I have used this version of RSLogix on a Windows 7 64-bit computer before with no issues. Does anyone have any suggestions?
________________________________________________
<?xml version="1.0" encoding="UTF-16" ?>
- <WERReportMetadata>
- <OSVersionInformation>
<WindowsNTVersion>6.1</WindowsNTVersion>
<Build>7601 Service Pack 1</Build>
<Product>(0x30): Windows 7 Professional</Product>
<Edition>Professional</Edition>
<BuildString>7601.24354.amd64fre.win7sp1_ldr_escrow.190108-1700</BuildString>
<Revision>1130</Revision>
<Flavor>Multiprocessor Free</Flavor>
<Architecture>X64</Architecture>
<LCID>1033</LCID>
</OSVersionInformation>
- <ProblemSignatures>
<EventType>APPCRASH</EventType>
<Parameter0>Rs500s.exe</Parameter0>
<Parameter1>5.20.0.18</Parameter1>
<Parameter2>3c5efc96</Parameter2>
<Parameter3>RS0AUT32.dll</Parameter3>
<Parameter4>4.7.3.0</Parameter4>
<Parameter5>3898654f</Parameter5>
<Parameter6>c0000005</Parameter6>
<Parameter7>00003b49</Parameter7>
</ProblemSignatures>
- <DynamicSignatures>
<Parameter1>6.1.7601.2.1.0.256.48</Parameter1>
<Parameter2>1033</Parameter2>
<Parameter22>f733</Parameter22>
<Parameter23>f733ddc95917d3fbca65f7f658f8eda3</Parameter23>
<Parameter24>f50c</Parameter24>
<Parameter25>f50c938b726b48d6ad667088a1c5b2fc</Parameter25>
</DynamicSignatures>
- <SystemInformation>
<MID>E40F1128-625B-4F2A-B25E-CD35F1958E2A</MID>
<SystemManufacturer>Panasonic Corporation</SystemManufacturer>
<SystemProductName>CF-53ACGBX1M</SystemProductName>
<BIOSVersion>V1.00L14</BIOSVersion>
</SystemInformation>
</WERReportMetadata>
I would try version 8.3( only 33M) and move on.
But if you insist then try right right all exe files, including your dll file and make it compatible w/ windows xp
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
87
I have a little bit of experience with Allen-Bradley. I have a Micrologix 1500 (RSLogix 500) and a PanelView Plus 7 (FactoryTalk View Studio ME)...
174
buen dia. tengo una falla al pasar los tags de mi plc SLC 5 0/4 a mi panel me aparece un error Problem writing value " " to item <tag name>...
85
Will someone please convert this logic to pdf?
127
Hello, Haven't been on in a while. I need to generate a bit level pdf of the I/O for RSLogix 500. I can generate a report but it just shows the...
162
