RSLogix 500 RSTrendX full width pen
OkiePC
Mar 2005
ENE of Nowhere Oklahoma
11,794
Trying to add tags to the trend as full width for process limits, but the software changes them back to analog...
Running RSLogix500 version 7.10.00
I did a quick search through the Know-base and Help with 0 results. Any ideas?
EDIT: Probably an unrelated symptom: It won't let me change the description field either. It is overwritten by the RSLogix500 address description.
I don't have a positive answer but why is the width greyed out on pens 3 & 4? My guess is that it is related to your problem. Perhaps the "style" is preventing this. Maybe??
OG
The width is greyed out because the style is a dashed line. Only solid (default) line styles allow a width other than 1.
I will try setting the style back to default though, just in case...
EDIT: Nope...didn't help but thanks for trying!
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
89
I have a little bit of experience with Allen-Bradley. I have a Micrologix 1500 (RSLogix 500) and a PanelView Plus 7 (FactoryTalk View Studio ME)...
180
buen dia. tengo una falla al pasar los tags de mi plc SLC 5 0/4 a mi panel me aparece un error Problem writing value " " to item <tag name>...
85
Will someone please convert this logic to pdf?
128
Hello, Haven't been on in a while. I need to generate a bit level pdf of the I/O for RSLogix 500. I can generate a report but it just shows the...
163
