RSLogix 500 Server Busy Error Message
bright676
Nov 2012
va
494
I keep getting this error when I open it and the I have to Cntl-Alt-Delete to get out of it.
I also have FTVS-ME installed but I even rebooted and just tried opening RS-500 and get the same error.
Any ideas?
I've had this error for quite some time and the RSLinx restore mentioned in the thread gclshortt referenced didn't work. After several minutes, pressing RETRY clears the SERVER BUSY dialog box away and everything is back to normal. Its annoying but I've never experienced anything more than that.
Came back again
The error went away for a few days after I closed every thing in the task manager that had RSLinx in the name.
It just came back again and its not going away no matter what I try.Any ideas?
WTF??? Error is gone now
As soon as I posted the last message and reopened RS-500 the error didn't come back, Weird.
I see this a lot when I try to invoke RSLinx from within RSLogix. While the error appears, I just find a shortcut to start RSLinx directly and that clears it up. I never dug into the root cause since my workaround has it going promptly.
I have been having this same problem. It has plagued me for months
uninstall and reinstall did not thing to help. I just have to await acouple minutes before it decides to go away.
After reading this thread I set the RS Linx Service to auto start. I thought that fixed it.... but nope it is driving me insane.
it seems it only helps if you run it as an application???
<Rant>I hate Allan Bradley's Antique Software and the Joe Maintenance guys that make me use it.</Rant>
This error is inconsistent. Most of the time I try to open RSLogix500 it gives me the error along the lines of "Server busy, action cannot be...
19,131
Alright, here is what I know. In the lab we are building a new OSIsoft PI system and need to inject some real life data into the machines for...
11,734
I have investigated the option to put password for specific routines into RSLogix5000 as requested by a customer for an CompactLogix project. Ok...
17,825
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
87
