RSlogix 500 timer issue
bearsgone
Jun 2010
chico
49
Hello
I have: 2 pumps that alter every time pump 1 or 2 runs based on level. Problem is that I can not reset timers after the first run. Logic: As soon as level drops below 30, reset timers.
Any suggestion on how to improve will be greatly appreciated.
You could try using TON timers instead of RTO
<TIME ON> timers only time whilst the rung conditions in front of it is true, and automaically reset if conditions are false.
<RETENTIVE TIME ON> timers retain there value if conditions go false and require a reset.
Choice 2 use a <LES> than 30 then <RES> to reset your timer
Just to elaborate on Gil47's post, you can also use the "reset" instruction with the same address as the timer you want to reset. When rung conditions are true preceding that instruction, the retentive timer will reset to 0.
Why is it that I Can't drag Done bits from timer, when I can drag Bit values into an instruction?
2,429
Hello friends! Might someone be able to give me a brief explanation of the differences between the .TT (Timer Timing) bit and the .EN (Enabled)...
1,874
I ran across something new today. Tried to change the timer preset on T10:21 but it would change back. Found that the preset was set by N124:23. I...
3,566
I am working on a project using a Allen Bradley ML1400 and would like to make it so the user can adjust a timer preset from the lcd. Does anyone...
6,159
I'm trying to simply change a timer preset value from 100 to 500 (x .01 sec) using RSLogix 500. It allows me to highlight the value and type in...
7,949
