TurpoUrpo: Bottleneck only? Is next station downstream faster than these 24 for now? can it get to the point where these 24 are faster than downstream, if it does in what way it would affect this "time critical"?
The next station downstream is currently only faster because units in the 24 stations are often delayed by the constraining "only one unit on the main conveyor logic" It would be ideal if these 24 stations were capable of operating faster than both the upstream and downstream stations. It typically fills up or empties in order to the balance the flow of the rest of the line.
Being faster than the downstream station would not have a negative effect on the critical time. Units are able to continue to be connected to the machine even after the machine process has completed. Time only becomes critical after the operator physically disconnects the unit from the machine and "releases" it.
Lancie1: Mike, Okay, the situation is different than I assumed. I thought the machine signaled when a unit was done, but I see now that the operator must intervene. That paints a different picture. Now your PLC cannot choose which unit (the closest to exit) to unload, but must wait on the operator.
That is correct. The machine does signal when the unit is done, but ultimately it is the operator the disconnect and releases it after they receive this signal. There is currently a team that is looking into automating this process and the PLC would then be required to determine when a unit is released after the machine has completed the process, but until then, we rely on operator intervention.
Thank you for sharing the sort files!
