RSLogix 500
There are screen capture programs, but I just use the Print Screen (PRTSCN) key to take a snapshot of the entire screen (or ALT-PRTSCN for just the current window). This will put it in the clipboard. Then just open any image editor (I like IrfanView) and 'paste'.
-Eric
Hi
You could save the program and then go offline and this would actually hold the hole program state , values in word , actual values that the timers are at etc
Not sure if this helps
Donnchadh
There is no built-in "take snapshot of screen" feature in RSLogix 500.
I use a utility called FastStone Capture, because I like its built-in editing and ability to automatically capture scroll-bar windows.
But the easiest method is to use Alt-Printscreen and any image editor, including Microsoft Paint.
A very definite (y) for FastStone Capture, been using it without any gripes for several years....
Top feature is that it will run from a memory stick : no installation required : no footprints left....
"PrintScreen 2000" also allows only capturing the active window (instead of the whole screen).
Nice little TSR (started from the "Startup" folder)...Just hit ALT>Print Scrn and up pops your screenshot.
But I will take a look at FastStone Capture.
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
108
200
buen dia. tengo una falla al pasar los tags de mi plc SLC 5 0/4 a mi panel me aparece un error Problem writing value " " to item <tag name>...
97
Will someone please convert this logic to pdf?
144
Hello, Haven't been on in a while. I need to generate a bit level pdf of the I/O for RSLogix 500. I can generate a report but it just shows the...
173
