Rslogix 5000 .acd file conversion from version 11 to 13 (fatal error)
clementaliu
May 2006
Lagos
Hi everyone, I have got a problem with upgrading a file on one site from version 11 to 13. once i open the file on rs logix 5000 and i want to change the version of the controller to version 13 it crashes and gives me the following;
error 0x80042001 (-2147213311)
RxE_NOT_FOUND - Requested item could not be found
L5k
Try saving the file as an *.L5K instead of an *.ACD
I have had issues when trying to flash firmware from older versions such as 11,13 to 15.
Converting the file to L5K worked for me.
As for the error code, cannot help.
Could someone please generate PDF report for the ACD files on this dropbox link? https://www.dropbox.com/s/47bntjys0nn8p1w/ACD_files.zip?dl=0...
2,201
I NEED TO CONVERT THE RSLogix 5000 .ACD (LADDER LOGIC) FILE TO PDF, CAN ANYBODY GUIDE ME (STEP BY STEP) TO CONVERT THE .ACD FILE TO PDF OR ALL THE...
5,393
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
62
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
169
