RSLogix 5000 Cascading PID
jstrebe
Jan 2008
Neenah
Ok!
I could really use some help getting off the ground with this one. I have in the past programmed cascading PID's but for some reason I can't seem to remember how this goes.. I have been working with Siemens for the last eight years and now suddenly I find my self working with RSLogix 5000. I have a fluidbed dryer that is heated via a duct heater. I need to control the % of moisture of the product that is exiting the dryer by controlling the gas flow to the duct heater. I have before and after dryer moisture probe inputs. I also have RTD inputs before during and after the dryer. My question is what do you guy's think would be the best way to control this process? I was thinking of cascading PID's But for some reason I can't remember which order I should put them in.
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
93
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
196
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
641
First off, I'm a hobbyist-level programmer, and this program isn't controlling anything anything that could even remotely be considered "life...
18
575
