RSLogix 5000 cross reference including base tag problem
May 2013
big rapids
Hello. I am having a problem in RSLogix 5000 that I have never seen before, and my co worker is having the same issue. When we cross reference a tag, instead of cross referencing just that specific tag, it cross references the base tag for that tag as well. Example: I cross reference test.hello.plc. Instead of just showing me cross references to test.hello.plc, I get ALL of the cross references for anything under test and test.hello.
I know I can change it from "show all" to just a specific referenc on the top like this:
but I have to do this every time I cross reference. Basically under that reference tree, I want it to just have "VOLT2_SIDE.SUHNER_SLIDE_2.EXT_PB" instead of both that and "VOLT2_SIDE".
Any advice on how we can fix this? It doesn't happen on our other projects. Just the new ones we have made. Thank you for your time.
The cross-reference is designed to be comprehensive, and used as a debugging tool it is second to none.
In your case, you see it returning results you are not interested in, so use the filters as you described.
It is not a fault that needs to be "fixed", some day you will need the x-ref results that it gives by default.
I have a UDT tag that has about 30 members. I want to cross reference just one member of it. When I right click on a specific tag member to...
2,755
The cross reference tab brings this window. I already tried resetting the toolbar to factory, same results. What am I doing wrong. I need the...
3,400
is it possible to activate cross reference display in the Rslogix 5000 like in this picture?
3,693
Did RA take this feature away in v20? I swear I use to use the cross reference to find AFI's and other instructions in logic in previous...
2,776
Hello eveyone Can someone please explain to me what does bits cross referencing mean in rs logis 5000? Thanks
3,472
