RSLogix 5000 Ladder Programming issue
chandrapaul
Mar 2016
bangladesh
119
hi,
i know how to write program in rslogix 500. in youtube video of rslogix 5000 programming i saw that they are just writing character tags (like start,stop,motor...) for input and output commands. there they dont assigning any input output address like I:0/0,O:0/0 like rslogix 500.
my question is if they are not assigning any I/O address in rslogix 5000 then how to know that which tags are correspond to which I/O port of the PLC?
thanks
If they aren't aliasing, then they are buffering I/O at some point (reading/writing those tags to the corresponding I/O points). Or maybe not at all if it's only a programming demo.
The Logix5000 Controllers use the "Local" tag to name I/O that is placed in the Local chassis. So for a input card placed in the first slot the tag name would be "Local.1.I". Which would be the same as I:1 in 500.
Since the new cards have way more data than the older SLC stuff they break down the tags into categories and give each item a name like Fault, Data, Config, Etc. This helps you to know what is in that category. So for the actual I/O Data you would look in the Data category. There is were the actual input and output table is stored. So for I:1/1 in 500 that would be Local.1.I.Data.1 in 5000.
You can create Alias tags that act as place holders for the Local tag. Alias tags (Pump_1_Run) are much easier to remember than Local.1.I.Data.1 You just create a tag and in the Alias part add the Local I/O you want that tag to represent.
Attached is a screen shot of one of my projects tag database to give you a idea of what I am talking about.
Thanks a lot...
How can I achieve the same functionality in Studio 5000? Image 001.png for the old RSLogix500 program Image 002.png for conversion to Studio...
2,526
I don't think I'm going crazy.. Lately when I have multiple routines open in the ladder editor and I open another one my tabs at the bottom only...
2,456
Hello PLCS.net! Here again to ask about how to do some weird quirky thing with RSLogix 5000. I see my team trending a lot of tags, but it becomes...
1,556
Hello, Have aoi written in Ladder to pass in and out string variables. String VAriables that interact with PLC program are declared as InOut...
4,314
Hi folks, I have a piece of code from my first project that I'm looking to improve a bit so am looking for some advice on how to do so. There's...
2,843
