I don't know if this sort of debugging tool exists, but is it possible to "record" the states of tags in a 5000/Studio project over time and then "play back" later (while offline) as a "simulation" to see what happened?
Write into a circular buffer the values of interest and a time stamp. Stop on whatever condition.
OR:
Use the PlantPAx P_Intlk AOI and look at the first-out status when the object trips. I rolled my own based on this model and extended possible conditions from 16 to 32.
OR:
a) The buffer depends entirely on the required monitoring interval. If it’s too small, make it larger. If the buffer size demands more controller memory, buy it.
b) You aren’t limited to one interlock object instance, nor should you try to shoehorn one into handling an entire process. We use one per device and our most interlock-dependent ones typically only approach 50% of the available inputs. Scope and break your problems into meaningful chunks.
