RSLogix 5000 prompts for FactoryTalk login
dmned64
Jun 2013
Florida
99
Recently I shared an RSLogix 5000 (v30) project file with a colleague. When he attempts to open the file on his computer a FactoryTalk login window appears. In the project file I do not have security enabled on the controller so I do not know why he is receiving this login prompt.
I have read several Tech Connect article and threads in this forum but none seem to specifically address this issue. As an OEM I cannot anticipate all the client names and their computer names to configure FactoryTalk security policies to allow them to open and view RSLogix files.
Is there a simple method for allowing project files to be shared between users?
Well the easiest way to share would be to create runtime application (If machine edition)
send the .mer to your friend
they use application manager (integrated within FT Studio under tools) and restore runtime application
They will have a usable copy.
If you did this and you have your current problem just let me know.
For those still dealing with this issue, i found a miracle solution from a user in a different forum.
You can run run C:\Program Files (x86)\Common Files\Rockwell\silentFTDCW to reset it
Hope this helps!
Hope this helps!
Worked great. thanks Rallen
It works perfect to me too!!!
I changed the computers name and the problem starts. After run the "SilentFTDCW", fix all the problems!!!
Thank you!!!
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
156
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
577
First off, I'm a hobbyist-level programmer, and this program isn't controlling anything anything that could even remotely be considered "life...
18
517
Hello all, I have a question in regards to RSlogix 5000. I am having issues with the program force closing when I try to make online edits. We...
119
