RSLogix 5000 won't open project, missing security info.
Just got worse; trying to reinstall it and bombed out, logs shows:
RSLogix 5000 Setup: ERROR: MSXML4 analysis failed attempting to instantiate DOM:
Reason: 80040154: Class not registered
RSLogix 5000 Setup: Attempting to register: C:\WINDOWS\system32\msxml4.dll
RSLogix 5000 Setup: LoadLibrary failed with: 1114: A dynamic link library (DLL) initialization routine failed.on: C:\WINDOWS\system32\msxml4.dll
RSLogix 5000 Setup: Could not register file [C:\WINDOWS\system32\msxml4.dll]
RSLogix 5000 Setup: Rerunning MSXML4 analysis
RSLogix 5000 Setup: Begin MSXML4 analysis on [E:\Software\Rockwell Software - AB\RSLogix5000\20.04.00-RSLogix5000-Web\RSLogix5000\Config\V20.04_web.xml]
RSLogix 5000 Setup: XMLM: MSXML is not functioning so configuration file at [E:\Software\Rockwell Software - AB\RSLogix5000\20.04.00-RSLogix5000-Web\RSLogix5000\Config\V20.04_web.xml] cannot be parsed
RSLogix 5000 Setup: End creating media list needed for edition
RSLogix 5000 Setup: An error occurred during loading
Update: Called support and they have to reinstall som XML parser in the /system/ directory of the install files using msxml.msi.
Tried to installed 20.01 but it didn't take even though it seems everything installed. Tried 20.04 and it worked.
argghh...
Have a look here for the opening of ACD files issue...
20546 - RSLogix 5000: Getting Class Not Registered Error 717-80040154
Access Level: TechConnect
And here for the installation issue...
116973 - Installation ERROR: MSXML4 analysis failed attempting to instantiate DOM
It appears they are both related to the same MSXML parser going awry.
Regards,
George
argghh...
Hi Harryting,
I got the same issue when I re-installed V20.01 RSLogix5000. Did you get your problem solved? How does RS Tech support suggest?
Thanks,
I forgot about this thread. I must have it worked out.
Try 20.04 instead, it's backward compatible with both 20.01 and 20.03.
Hello, I am having a problem communicating with a RSLogix5000 program on a machine a usually do not have a problem connecting to. I am still a...
3,334
So I had this problem last night, and could not find a fix anywhere on the internet.. Called Tech Support this morning such an easy fix I figured...
8,586
Is this a bug in RSLogix 5000, or is there something wrong. I cannot get the TONR command to work in a sequential function chart; I can get it to...
17
9,693
I'm getting the following error message on a file that I have been working on all day: Failed to open file 'C:\.....program_name.ACD'. Project...
35,326
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
157
