RSLogix Sequencer
tim_callinan
Apr 2012
Annapolis
59
Hello All,
Im alot more experienced with the CLICK PLC - They have a pretty user friendly Sequencer in their ladder logic software - very easy to use. Im a teacher and I also use RS 500 and am starting to use Studio 5000. The allen bradley sequencers seem not intuitive as the click PLC one. I would have thought with studio 5000 coming out - they would have had a library with a more user friendly sequencer - Am i missing something or does anyone have any advice.
Thank you,
Tim
Despite many options across a few platforms, when it comes to sequencers, I'm still in the habit of making my own by using EQU > MOV, and having a bunch of outputs at the bottom of the routine.
Simply because it's habit and if there is a situation where a sequence option that is hidden behind a 'pro' version, our customers can still see what is going on without having to upgrade their std version.
Hello guys I have to make a program using a SQI and SQO instruction in order to extend/retract 8 cylinders, one at a time. Each cylinder has 2...
1,855
I have a control process that needs to sequence through a number of steps using the same input. Hitting the same pushbutton should "step" the...
17,091
as i am still a little new to plcs, i need a little help. i have read the slc 500 instruction set to try and comprehend the sequencer output...
7,881
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
87
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
157
