RSLogix V32 Produced/Consumed Tag Issue
0151paul
Dec 2017
Liverpool
Hi All,
I have a new 5 PLC system. Each has the same firmware revision. Each PLC has the same User Defined UDT for Safety Tags.
PLC1 reads from PLC2 & PLC4
PLC2 reads from PLC1 & PLC4
PLC3 reads from PLC4
PLC4 reads from PLC1, PLC2, PLC3 & PLC5
PLC5 reads from PLC4
I have an issue with one connection, the connection PLC4 makes to PLC1 (PLC2 has no issue connecting to the same Tag in PLC1). All other connections in all the PLCs are working fine.
The error I get is - Code 16#0100 Module is in use
Now I have checked the number of consumers, RPIs, Tag names, UDT, SNNs are correct. I've exported the modules and tags from PLC2 (working connection) into PLC4 and renamed to suit in case there was something I missed but I cant get this one connection to work.
If I change the Tag in PLC1 & PLC4 from the safety class to standard class the connection works but when its a safety class I get the error above.
I've recreated the problem with a new Tag that is only consumed by PLC4 but the same issue occurs when its a safety class tag.
Any ideas what I'm missing?
Thanks, Id already seen that thread and started a new one as it didn't really cover the issue I was having.
After trying everything I could think of I re-flashed the PLC (PLC1) and then redownload the program and everything worked ;)
Hello, I am trying to export some add on instructions & sub routines and import them into a program that is in Rslogix 5000 v20. The program...
1,765
I'm very new to PLC programming and need help setting up a communication path. i would appreciate it if someone could please explain to me how to...
5,869
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
87
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
156
I have a little bit of experience with Allen-Bradley. I have a Micrologix 1500 (RSLogix 500) and a PanelView Plus 7 (FactoryTalk View Studio ME)...
168
