RSlogix5
Tim Michols
Feb 2018
germantown
Hi , i'm looking for copy of RSlogix5 or a laptop with that software on it. I need it to upload code ,so i can rewrite it. any help would be appreciated.
If you're in Germantown, PA, contract Rumsey Electric, the local Rockwell distributor. They either may be able to help, or put you in touch with a local system's integrator (there are several in the area).
It's still going to cost a bit though -- typical rates are $150 /hr, 4 hr minimum (which is probably all you need).
Yes, Already checked with Rockwell, they want $10,000 just for the starter version, which is hard to spend for just one use. Thanks
Sounds like a hell of a deal... :oops:
A simple service call should be your cheapest bet, do you know any local integrators ?
Can you not download it and run on the 7 day grace period to do an upload if all you require is a backup?
If you're wanting to re write and commission, if it's a one off job, probably more cost effective using an SI.
No I think you still need a serial number to download it, 10k is on the verge of insanity for any software
And yet, people go to war to defend Rockwell...
Just I defend people here charging $ for their work. Yes.
I'm quite it doesn't cost $10k, it's some # the OP throw out to make a point but as most pointed out, it's better just to hire out this job and maybe long term replace the PLC. PLC 5 parts cost an arm and leg now even on eBay.
List price is $9,980.00
when you say "rewrite it" do you mean "translate it" into some other platform? ... for example from RSLogix5 to RSLogix5000/Studio5000 ... if that's what you're planning, then WHO will be doing the translation step (you or someone else)? ... maybe you have more options that we haven't considered yet ... (no "silver bullet" - but maybe something helpful) ... the more we know, the more detailed help we can offer ...
I could use some help figuring out the layout of a Remote I/O channel Diagnostic Files in a PLC5 using RSLogix5. I've attached a screen shot of...
3,662
Hi all. I was wondering if anyone knew a way to renumber Ladder Numbers in RSLogix 5. I have deleted some of the old Program Files in my Project...
1,534
Yesterday a coworker informed me of an issue with his laptop. Anytime he opens an RSlogix5 project, and tries to go online, the entire program...
1,386
Hi Friends, 1. Please, what are the differences between RSLogix5 and RSLogix500? 2. Troubleshooting/Fault finding tools in RSLogix5? 3...
1,128
I'm having issues opening RSLogix5 version 8.0.0.3. on Windows 7. The program is unable to load and an error message stating "RSLogix5 PLC5...
1,990
