RsLogix5000 AOI import
tarik1978
Mar 2010
casablanca
716
Hi
I have downloaded some AOI"s and a demo application from Siemens website for S120 servodrive.
I cant open the demo file, I have version 16,17,18 and 19 installed
also I cant import the AOI's
could someone please open the demo file, import the AOI's and convert to one of the versions I have.
Many thanks
AOI's attached but the demo file size exeeds 300KB I put it on Dropbox
https://www.dropbox.com/s/2j20ohly4cw4eyb/EIP_S120_G120_Completed.ACD?dl=0
The ACD file shows version 20.0 - open in Notepad - last 'save' entry is the version.
The AOIs show version 19.1 - open each in Notepad - near the top
Try starting an empty project in 19 then attempt to import the AOIs.
You'll have to install 20.0 to open the ACD. 'Downconverting' an ACD is rather tricky.
The example File was in v20 BUT also used the 1769-L16xxx processor which doesn't have v19 support. I converted it using the 1769-L32E processor and in the L5K format which is smaller in size for purposes of the forum. Hope this helps, I know how important it can be to have an example of code that "works".
I am trying to create a simple AOI that takes in a standard compound data type and a number (as either an INT or STRING, whichever is more...
2,965
I've got a question for those of you with Ignition experience: I've been interested in Ignition for a few years now, have not had a chance to use...
1,884
Folks, Having a silly problem. Trying to package a routine up that needs to be repeated ~~50 times into a nice Tidy AOI. I need to do some...
2,312
Need good example/sample of aoi RSLogix5000 code to read&write through RS232 port on Need good example/sample of aoi RSLogix5000 code to...
1,843
Does anybody have run into the issue when the same structured text code from a subroutine has hiccups while copied/pasted an AOI? The issue is...
6,264
