RSLogix5000 Message Control Tags
onurich01
Apr 2004
Indianapolis
Where is the information for RSLogix Message Control tags stored. Some of the information is accessable but some is not. I recently developed a control tag shell, and built 2 programs into when(one task, 2 programs). The messages were configued in the programs, and the message tags(have to be controller tags) were configured to match. When the program was built and I clicked on the elipsis button the message was a "CIP Generic" instead of the "PLC 5 Write" I had configured. I believed that I had found a work around when I reconfigured the messages and then stripped the programms out of the shell. But when I DL to the PLC I found that the tags were really not changed. We will be doing this in more applications, and I need to find a way to ensure that our controlled software really is controlled when we build each project.
Right click on the message tag in the tag browser.
Select "Go to Message Properties", somewhere in the middle of the popup menu.
Was this what you're looking for?
Hello, I have a question on an OCR application I am doing. I am reading in 16 characters that come from a camera into the plc in its input words...
1,280
I want to read several disparate values of different data types from a second PLC with the MSG instruction via CIP Data Table Read message type...
5,035
Hi Guys, Recently we had a third party integrator add a Fenetech scanner to one of our lines, and made many changes to our PLC program. It sorta...
2,470
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
128
