RSLogix5000: Open Sockets: Create Socket Issue
aka00devon
Oct 2012
Philadelphia
Hello,
I'm having an issue with creating a socket using a message instruction. I've attempted to copy the data structures from sample programs found in Rockwell technotes 32962 and 33672. I'm hoping you could catch my flaw in the description and pictures below. Please don't hesitate to ask if there is additional information I can supply to you.
=== Hardware
PLC: 1756-L61, Rev. 20.11
Card in use: 1756-EN2T ("Ethernet"), Rev. 5.8
Slot: 1
=== MSG Instruction
Path: 1,1 (displays as "Ethernet")
Error: 16#0001
Extended Error: 16#0009_0315
=== Image Link
http://imgur.com/a/ukLRr
You probably need to post your program or use TN 32962 without any changes
This error is an indication that you are writing illegal path string directly to the MSG.PATH bypassing the GUI and this string syntax is not correct.
Does anyone know a fast way to find which desktops on the network (by IP) have open copies of a communal program on the same network? Our issue...
1,736
Whenever I doube-click a RSLogix 5000 v20.04 .acd file, I see an process popup called Logixdesigner.exe in the task manager but it never opens up...
3,183
I don't want to polute other threads where people were asking this question: RSlogix5000 v16+: how to open local PDF manuals in a separate window...
3,111
I am able to save a recorded trend to a log file. This file has an extention "TBS". For example "mytrend.tbs". Now I want to be able to open it in...
34,497
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
139
