rslogix5000 pide autotune help
madhatter83
Feb 2013
Toronto
Hi, i have come a across a problem and i am hoping someone is able to answer this question. My application is for a small level control system. There are two control variables, a VFD and a control valve operated by a i/p converter. The intention was to control the process using function block and possibly cascade control and autotune. I am having a problem with the autotune function using a control block. All the manuals I have read say the process must be in manual mode. However, I am not sure how this is done. When I try to operate the process from the ladder logic it wont allow me to download to the function block in manual. I am not sure what I am doing wrong and any feedback would be greatly appreciated. I am attaching a copy of my program in order for anyone to browse and look at.
Thank you in advance.
this subject has been cropping up quite a bit lately ... since I was already doing some course development work along these lines, I've decided to...
7,987
Hello All, Looking to get a better understanding behind an issue that I had earlier today with a PIDE Instruction that was not changing it's CV...
1,270
Hello, I am trying to figure out the difference between Hand Mode, Override mode and Manual mode and what advantage one has over the other. The...
2,643
Hello, I am trying to modify an existing program because the temperature is not stable (according to the operator it was never precise). So, I...
5,414
Hey all! I am using a PIDE (and indeed an FBD logic) for the first time. I have two questions. 1. I am running PIDE to speed control. Speed is...
8,229
