Hi all. I went to a site today that has AB processors/HMIs on an ethernet network. They're not all mapped to each other and I needed to add one of the CLX processors to the group so that I could Msg between them (1756-ENBT/A in both cases). So: Right click on the network icon under the parent CPU and add new. Pop-up lets me enter all the information, node name/IP address/rack size/adapter slot etc. I set the keying to "compatible" and format to "Listen only" as I couldn't find definitions for any formats in the local help files and at this stage I've only been asked to send one bit from A to B. On hitting OK, it showed the warning about adding the device to the network and to set comms to off. Seemed like a good idea to me. But then after a couple of seconds gave me the pop-up message "Failed to modify module properties. Not enough data." As there are no other tabs on this dialogue I'm stumped. Does it mean not enough data in the set up dialogue or in the connections to the processor? Any pointers would be appreciated. Thanks.
