Hi FYI, I am new here ;o),
first an explenation: I have a Micrologix 1200 PLC, a serial to Ethernet adapter (from AB), a Endress + Hauser Ultrasonic controller, Keypad (with microcontroller sending code over rs485).
The setup: Ultrasonic is monitoring a diesel tank. this info is transmitted via 4-20mA loop to the micrologix analog card. alarm is than sound, if tank level to low.
A employee wants to fill up his forklift and has to punch in his code. The code is sent to the PLC, the PLC checks the MicrosoftSQL database via RSSQL (Ethernet), and if valid, the PLC startes the pump.
Q: Is it possible to set it up this way? I don't know what exactly I need to make it possible. How the code should look. Can I read with my plc from the SQL database? Can somebody help me on this?
Thanks,
Eddi
Thanks,
Eddi
