RSSql OPC Data Point Setup
skyfx
Oct 2009
IN
Hey all,
I am trying to define data points in RSSql and am having some problems. I have a ControlLogix 5555 controller and an OPC topic set-up in RSLinx which is pointing to it, but RSSql is refusing to populate the tags in the data point definition window, as shown in the following screenshot.
RSSql's help file says to use "Generic OPC" for ControlLogix PLCs instead of "RSLinx Classic OPC" in the inital configuration, shown below.
While choosing "Generic OPC" enables me to see the OPC tags from my tag database, as shown below, I encounter some other problems (for e.g., I can't add the array containing the data for a tag of type string - I would have to add all [82] elements of the string and set-up a data point for each, which is not feasible).
Any ideas :)?
Thanks!
P.S.: I also tried exporting my tag database from RSLogix 5000 and just importing that for my data points, but then I lose a variety of tag details such as the fact that a tag of type string has a .LEN component and a DATA array.
Problem solved - FactoryTalk Live Data, set-up via the FactoryTalk Administration Console, is the way to go for your Control Connector Service :)!
Hi, I am currently in need of help with regarding of the ways on how to connect RSSQL to suitelink without using 3rd party driver...your reply is...
1,098
Hello all I am a student and also very new to PLC's and RSSQL. I have a situation where I am trying to link rslinx classic to ms sql through rssql...
2,294
I'm trying to get a string from the plc and store it in a database, but I can only get the first byte, I know there should be an easy solution to...
1,924
Hi Everybody, While I am trying to start configure RSSql,I m getting Error(33190)'The service could not validated using specified username and...
3,454
I need to setup a trigger as an unsched event specified to bit level. I can do this currently to word level, but it is kind of a waste. I do not...
3,452
