RSView 4.0 and RSLogix500 Emulate
Joker460
Jan 2008
Here
Something strange has happened.
I have a RSView 4.0 ME program setup for RSlinxOPCServer.
I have a RSLogix500 running in emulation mode which works.
I have done this before without any issues but this time when I run "Test Application" in RSView 4.0 a window pops up with 2 hour limit (I'm aware of this limit) and has "load application" and "terminal Settings" buttons showing.
If I select "Load Application" , a file selection window pops up. The application is nowhere to be found since I never created a run time application.
Before, when I ran "test application" the application would pop up in the top left portion of my screen and I could test away.
Any ideas to what may have changed.
Thanks in Advance
I am working on a small project which aims to calculate the number of starts and failing a series of motors and for this I wrote the program that...
1,306
From a Test Post: RsLogix 500 ver. 6.2 Here is the problem. I had rsview 4.0(CPR 7) on my laptop, new customer using Factory Talk 5.0(CPR 9)...
1,823
I cannot realize any inputs and outputs on RSView connected with RSLogix500. Because RSLogix500 don't give a possibilities to use any adresses...
7,208
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
317
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
261
