RSView and Siemens
Dawen35
Jul 2015
Conwy
17
Hello all,
Apologies if this question has been answered before, I have done a quick search and couldn't find exactly my problem.
I am currently adding a Siemens PLC to our RSView SCADA and whilst i have set up the OPC server and have managed to get my tags done I am struggling with my alarms. The alarms from the PLC are in Word format and and I am trying to get them in bit format.
I have managed to get my bits by using db##,#.# but seem to recall that if I want to take a bit out of a word (I think it is called indirect address) I need to use db##.dbx#.# , is this correct.
If my terminology is not right or this is a very basic question please forgive me but I have had a headache over this all day.
Regards
Dave
I've never seen them addresses as db##,#.#. I'm assuming that's an RSView way of addressing.
In the Siemens PLC, the way to address a single bit is as you have shown, db##.dbx#.#.
Like db3.dbx2.1 gives you the bit datablock 3 byte 2 bit 1.
The dB addresses are laid out like shown in the attachment.
S7-300 or 1200?
Thank you Tim for your reply, I must admit I was a bit confused with the comma myself but it seems to work so I have left it. I will try the way you have added above and see how it goes.
Hi all, Has anyone engineered a RSView SCADA sitting on top of a Siemens S7400? i have not come across this combination before, only RSView on...
5,359
I'm trying to connect my Siemens PLC to my AB PanelView 600+. I have the AB PLC conected without a problem. I'm not sure how I would go about...
14,010
i have been asked to look at using RSView with a Siemens S7400 PLC by our client. I have some reservations about using a system that lends its...
7,460
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
297
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
253
