RSView SE 4.0 Client Functionality
djlamb
May 2007
PA
I am developing a distributed SE application and having some problems getting clients to function differently. Basically depending on the location of the terminal the customer wants it to function differently...however they also want the ability to change that function if a terminal goes down. What i have done with view32 in the past is use the terminal name to accomplish this. I have a mental block and can not get it to work with the server client setup...anyone have any ideas????
Either use VBA, running in a permanent, always open window, and pass all of your display requests through that, OR make up several different 'menu' screens to callup displays, and assign different ones as the 'startup' screen in the Client shortcut.
Hi ALL i want to have a redandunt ethernet network with 2 server ,2 client and 2 switches and 1 engeeneering system. servers and clients and...
1,479
I have an RSView SE 3.0 distributed application running on a Client/Server. Can I use FTView 7.0 to develop some new screens and or modify...
3,915
We have a RSView SCADA set up with an active display server running five RSView active display floatin clients. When the alarm log activates and...
2,666
I have studio running on a server and my full client licsense resides on that server. What I am needing to know is how you keep the client...
4,269
Hi All I am having a lot of problems in configuraing the Active display server & Client. I have two HMI computers , one is linked with...
14,082
