rsview se 4 v.b change sub
phinix
May 2006
l.a
33
hi 2 all
perhaps some body can explain me way ,when i put a
"private sub NumericInputXX_change " in my code it's content runs each time the window lods???
in plain v.b or v.b.a it loads , and only then waits for a chang in the numericInput ,
is ther any thing 2 do abut it??
phinix
No i Can't
no i cant ,there r 50 of them ,waiting for a chang to connect to a sql server and insert a line to the db .
Wellllll.... uhhh, if it's waiting on a change in data, to trigger a write to SQL, why would you want it disabled? Sounds like it's doing just what it's suppossed to.
Generally, I put those types of triggers in a hidden, always open window that launches on startup.
For any tag configured like that, if you have, or are every going to have, clients connecting, you absolutely must make the VBA code exclusionary to a single computer!!!
The simplest way, is to get the computer name on startup, and then in those functions, check to see if that computer should actually do the SQL write, or just return from the function.
If you have many identical buttons in RSView ME and you must change the same thing in all of them. Can you do it without entering them all. They...
1,615
I had to make a change of IP addresses on a machine. I made the changes and everything is fine. However everytime the computer is turned off and...
4,002
I need to order a few licenses and i can't seem to find it on rockwell's site. We are currently running RS View SE and when i go to the site, all...
4,362
After searching for awhile for obvious answers... I want to be able to provide software change control. The whole project name change process...
3,512
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
321
