RSView SE Running Slow
Joeay
Oct 2008
canada
Hi, I'm new to RSView SE however have used RSView32 in the past. The screen refrsh rate seems to be a way slower on RSView SE (It makes animation seem choppy). Any way to fix this?
The only difference was that Modicon PLCs were used with RSView 32, and Allen Bradley PLCs were used with RSView SE.
Yes, PLC data is controlling the animation.
Is it possible to change the update rate of the graphics?
I have seen this issue when the sceens are set to overlay instead of replace. Also check the AB site, there is a tech note on internet explorer settings.
Already checked the internet explorer one.
Also, this occurs even with just one display, and one shape on it.
The update rate for tags is set on a per-display bases in RSViewSE. To change that, open the display in the editor, and open it's properties page. On the bottom left I think, is the drop-down for the display update rate.
Note that this won't help much if the I/O server update rate is set for a longer time interval then the rate you enter for the display itself.
I am using rsview 32 works 1500 . it was running good in running it shows error "microsoft visual C++ runtime library " what is this error ...
1,499
I have a situation where I need to lock out the desktop access while RSVIEW is running. I want the project to run without the ability to call up...
1,787
Can, anybody suggest the way to run a RSView project while logging in as a non-administrator?I am getting error message when try to run the...
1,887
I was asked to back up the RSVIEW HMI project while it was running. I was feeling a little stumped so decided to just copy the files from the...
3,527
Does anyone know how to get the rslogix5000 plc program to automatically run when the panelview 1000 has gone through startup, programming done...
4,847
