RSView studio backup
chad k
Aug 2005
edmonton
Hi, everybody;
when I try to backup my RSView studio porject with application manager, the following pop up:
unable to create the archive 'c:\documents and Settings\All users\Documents\RsView Enterprise\ME\Archives\saw.apa'.
please check that the application is not open eksewhere.
I am quite sure that the application is not open eksewhere. Even I cold start the computer, the problem insisted.
many thanks for you help!
Trust me here, I feel your pain with RSView Studio!!
I too had this same problem when I first attempted to backup my application.
Once I briefly explain this, you'll be like.....oh, ok now I get it.
Launch RSView Studio on your workstation. At startup of the software, you'll be asked to select an application. Click on cancel and the software will remain open with a gray screen with very few items 'not' grayed out on the toolbar. Only here can you backup your application using the application manager.
You cannot backup an application with any application currently open.
If this doesn't do the trick for you, repost and I'll try explaining a different way.
thank you, Sir
but when try the method you supplied, the same popup occur.
I tried to start the Application manager itself with out RSStudio running. The problem still can't be solved .
any input would be appreciated!
OK, I've had the same in the past. This works for me;
Reboot your PC
Open RSView
DO NOT load any programs (press cancel)
Open the Tools/Application manager
Select your edition (I have ME)
Select back-up
Select your application
Enter the archive name
Finish
RSView/Application manager doesn't actually tell you the save is complete if it does it, so to be sure go look for it.
Default folder for Windows is C:\documents and settings\All users\Documents\RSView Enterprise\ME\Archives
file has extension .apa
You cannot do it if you have ever opened a file via RSStudio this session. You will HAVE to reboot. Good luck.
Yeah, I have seen the same problem too. Davegr is correct. Reboot.
Sometimes in RSVIEW ME, you will experience problems that don't make any sense..communication issues....tags.... Just remember, if you have exhausted yourself of all that you think is wrong, JUST REBOOT and it will work.
Good Luck,
BTW, the Siemens CC-Winflex software is a great alternative, with a lot more capabilities.
Hmibackup
Isn't "Hmibackup" what you need????
Hmibackup is a batch file (.bat) file that you download from AB and it will backup your RSVIEW while running (like it usually does on a server).
That's for SE, not ME. SE has defective backup problems all its own :)
Hello to all the knowledgeable people inside the computer screen, my problem at the moment is like the title says, l can't open projects in...
1,334
Hi Working with some project guys who have replaced a controllogix processor previously using RSLogix 5000 V11 for a controllogix 5588E using...
4,060
We have an older laptop here at work that has RSView Studio on it that isn't used for anything. They only use Red Lion HMI's now. I was thinking...
1,530
I have an RSView SE 3.0 distributed application running on a Client/Server. Can I use FTView 7.0 to develop some new screens and or modify...
3,918
Hello I am trying to get certain screen components to be visible unless an h/o/a switch is turned to manual I:0/8 being the input for the...
1,348
