RSView Tag .CSV import not working
RSL
Nov 2004
Missouri, USA
356
I am having a lot of trouble with the import export utility in RS-View 6.4.
I can export, edit copy and rename folders and tags. Then when I import I don't get any errors. It completes and then when I launch view all my tags and folders are just not there?
I am very tired, been up all night. It is highly likely I am doing something very stupid here?
I am at whits end on this. ideas anyone?
I used this thing earlier this week and it worked slick. Now I am completely stumped?
RSL,
I am using RSView32 Works, version 6.3. I have noticed a small quirk. When you import new tags, they often go into a new folder. Open "Edit Mode", "Tag Database". Now look in the lower left corner of the screen, underneath "Search For:". You should see a small tree menu, with a File Folder icon. click on the folder to see what else is in there! Your tags may be installed somewhere inside the main folder, but hidden from view until you open it up.
If you've had the database open whilst doing the import you won't see the new tags unless you presh the "Refresh" button (the one that looks like a paintbrush)on the button bar.
Hi all, so I am trying to get the correct version of RSview 32 Works to make some edits to the tag databases in some old HMIs we have. I did a...
1,000
Hi, I have RSView studio v4.0 running on one virtual machine, and RSLogix 5000 set up and running on another virtual machine. These are tied to a...
2,351
Hi, first sorry my english. I need help. Im using RSView32 7.40 I want to write value to a tag from Visual Basic. i calcualted something in...
1,366
Hi everyone, there's a problem and hope you guys help me solve it. When I am trying to import tag file (.rsv) file into the .rsv project file...
1,405
Hi Guys, Is there a tag search function in RSView Studio similar to the old function that was available in Panelbuilder 32 where you could...
3,056
