RSView32 and RSLinx Lite...
smohamed
Mar 2008
ON
108
Hey guys,
I know this topic has been beaten down in the past (as per the number of threads after doing a search), but I wanted to confirm something. I have RSLinx Classic Lite (2.54) and RSView32 (7.50) using Direct Drivers to communicate with a SLC 5/05.
I've seen that if you require OPC/DDE services, you have to upgrade from Lite... however, to cofirm, even using direct drivers you still cannot use Lite to communicate with RSView32?
Was there a time previously where older versions of View32 and Lite would have worked?
Thanks.
Hey guys,
Thanks.
Pretty sure it's always taken at least Linx Classic Single Node (or the equivalent) for RSView. I don't recall Lite ever working (been doing View32 for 8 years or so).
:hmmm:can anyone help with what should be the version of rslinx classic communication for rsview32 v 7.10
1,547
Hi all, i'm new on this forum. I have some problems with the communication with rsview32. The version is rsview32 7.10 and rslinx gateway. I am...
2,781
I am running Control Logix, RSLinx Pro (v: 2.40.01), with RSView32 (v: 6.30.17) and my display has no data. My driver (ETHERNET) is properly...
20
9,663
I am trying to monitor coms from multiple rslinx opc/dde nodes in rsview32. I have tried different ways to accomplish this, to no avail. I assume...
2,495
Does anybody have experience to install RSView32 in combination with RSLinx on a Windows XP embedded OS ? It will communicate to a Compact Logix...
4,137
