RSView32 Starting Multiple Data Logging Files
smohamed
Mar 2008
ON
108
Hey everyone,
I'm using RSView32 Works, version 7.50 and I have currently setup a few Data Logs to run. However, through the Startup (under the System Tree) you can only specify one to run at start-up. Does anyone know a way (maybe scripting) to get them all to start at the same time? The only way I can start them is to manually Run them at runtime.
Any ideas?
Thanks!
Instead of the RSview Data Log (designed to create only one log file), I use the Events function ("Logic & Control", "Events" menu) to set up as many log files as needed. These files are usually the CSV type (Comma-Separated Values)that can be read externally with a spreadsheet program. The Event function uses a Visual Basic file that you create, which contains the tags to be monitored.
Awesome.
I tried that (with the simulation I am running here) and it seems to work. Quite clean too.
If I don't program a shutdown macro to stop logging, I assume it will log the data even if RSView32 is not running?
Thanks again for your help.
Awesome.
I see through the RSView32 User manual that:
When a project stops, all data log models automatically stop as well.
To stop data logging without stopping the project, use any of the​
methods described next.
I also saw the DataLogOn command you guys were speaking of... right on the last page. Thanks again for your help!
Hello, since some days ago I can't open the Vba editor in RSView32 v. 6.5 It is installed on Windows XP. It is not giving any kind of error...
1,363
Hi u all Resp. friends... I m facing a strange problem in my SCADA software. I have PLC5 and RSVIEW32 as a SCADA software. The OS in my server is...
1,685
1,961
I have RSView32 running on a Win2000 Server machine. When the project is started, it takes 35-40 minutes to completely start. When looking...
4,706
Hello all, I urgently have to re-install the RSView32 Works onto the laptop. but i have lost the CD with the serial number. However I know the...
22,912
