RSView32 VBA error (not found)
phuz
Jun 2008
Mohnton, PA
1,044
We were given RSView32 project files, for quoting, that will be converted to FTView SE. Unfortunately the project has VBA references that were not included. If they cannot be provided, is there anyway to find out what the missing references are?
Event viewer only shows this:
Faulting application sptvbs32.exe, version 7.60.6.0, faulting module msvcrt.dll, version 7.0.2600.5512, fault address 0x0001186f.
The "msvcrt.dll" is Microsoft Visual C++ Redistributable. From my history of installed programs, "Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.6161" was installed on the same day that I installed RSView32. Check if you have this in your list of installed programs in Windows Control Panel.
Note: Only install RSView32 on a 32-bit version of Windows (mine is on Windows 7 32-bit with no issues).
Try going to Logic and Controls -> Visual Basic Editor
Under the Tools Menu, References...
That works....when the program actually opens. However, I'm seeing that I can now open this project on another VM and I'm only getting the msvcrt.dll error on the one machine. Maybe corrupt install of the redistrib package? Oh well. At least I can see the missing references in the other VM, which is what i was looking for.
The one that won't open starts to load the project, then:
Failed to launch the VBA Server. (OLE Exception 0x0).
RSView32
Couldn't start VBA Server.
Cause: Couldn't initialize VBA.
Cause: The specified module could not be found.
No, because it works on another XP VM just fine.
But in this one, when I try to open it, it gets most of the way loading, and then:
Unfortunately not it. I've had that issue in the past and it gives a different error. VBA server not loading appears to be something different.
The FM20.dll file exists on both the good/bad machines with the same file date info, too.
Good friends, I'm new to the forum, I'm working with RSview32, someone can help me how to make a macro in VBA, to save some data in Excel. to...
1,959
Hi, I got a RSview32 project from site with VBA scripts and trying to run on my local machine to make some graphical changes. VB scripts are used...
3,510
Please somebody upload this manual on another site or forward me 51770 - Sample VBA: Exercise in migrating an RSView32 application with VBA to...
4,918
Hello all, New to the forums here and glad to find this oasis of RSView/FactoryTalk info! I have a basic VB question I hope can be answered...
2,317
Hi, I'm pretty new to the RSVIEW32 & have encounted a problem whilst coding visual basic. The error is:- Compile Error: Sub or Function not...
2,167
