RSVIEW32 works importing trend data to a project
engiedude
Apr 2013
USA
Is it possible to import trend data into an existing project? I have previous trend data and would like to import it into the current project.
Yes, you can copy the saved data log files (including the trend data) from one project to another. Using Windows Explorer or similar program, look in your RSView Project file for a file folder called "DLGLOG", which is the saved DBF-type log files for all your RSView historical data that has been saved. Pick the dates (hopefully your files are saved using a date in the name) you want to copy, and copy and paste them to the DLGLOG folder in your new project.
To view the old trend, you will need a trend chart set up identical to the original trend (same tags and same number of pens, and so on).
what's the difference between Rsview ME and RSVIEW32 works and can'i migrate a RSVIEW ME project to FActoryTalk !!thnx....
1,569
Have a server running RSView32 Works. Somehow the Menu got screwed up and when you start the program, If you don't select the right screen (with...
2,965
Hello all, I'm new to the site, but thankful it's here! I just installed RSView32 on my computer for the first time. I have never run any...
9,344
Hi, (RSView32 Works v7.50) I have a problem with exporting and importing of graphic files between projects. I export graphics from one project...
4,200
Hi all, Is RSView32 Works capable of producing smart graphics, similar to that of faceplates or CitectScada's Genies & supergenies? Thank you in...
2,899
