rsview32 works: graphic import/export issue
jeffy
Jun 2010
Auckland
35
(RSView32 Works v7.50)
I have a problem with exporting and importing of graphic files between projects.
I export graphics from one project and then import them into a different project.
Some of the graphics turn out fine, but most of them turn out completely blank!
By viewing the XML file contents, it appears the exported graphic files appear fine and as expected. I've tried all sorts of things to try remedy this but still no joy.
I don't understand how this can happen. Has anyone experienced this before, and how did you resolve it? Thank you.
Were the graphics files you are importing created with a different version of RSView32. If I recall correctly, Rockwell changed the format at version 6 point something. If its an old project then open it in RSView32 7.5 and follow the prompts to update the project.
There is also an easier way to import graphics. Just copy the desired .gfx file into the graphics folder of the new project. Then open the new project. Right click on graphics in the project pane and pick add to project and then select the file you just copied. Hope that helps.
Do you mean the .gfx files or the bitmaps that they may contain? Newer versions of View should open older versions without a problem. Is the whole screen blank or just certain elements?
Thanks for the input guys. The project could well have been created before v6.00 so that may explain it.
Yes the .gfx file turns out completely blank.
I've just resorted to the alternative method rather than using the xml export/import method. THanks.
Wait. You shouldn't need to use XML import. It's been a while since I've used RSView. I didn't know it had a XML import. You just need to copy in the files.
what's the difference between Rsview ME and RSVIEW32 works and can'i migrate a RSVIEW ME project to FActoryTalk !!thnx....
1,569
Have a server running RSView32 Works. Somehow the Menu got screwed up and when you start the program, If you don't select the right screen (with...
2,963
Is it possible to import trend data into an existing project? I have previous trend data and would like to import it into the current project.
2,024
Hello all, I'm new to the site, but thankful it's here! I just installed RSView32 on my computer for the first time. I have never run any...
9,344
Hi all, Is RSView32 Works capable of producing smart graphics, similar to that of faceplates or CitectScada's Genies & supergenies? Thank you in...
2,899
