I have been reading the manual 1746-NR8 since my last post.
It discusses the configuration being sent to the module as 16 bit binary.
This means that the number 26588 decimal becomes 110011111011100 binary.
I did not know that it appeared as decimal. The manual does not mention this even as being an option(as far as I have seen). That is extremly good to know. I would have looked for 1 and 0 and saw 5 and 8 that would have been confusing. knowing in advance will be beneficial.
If I interpret this information correctly this is saying - 150 ohm resistance, 10 to the 4 power units, set to downscale, degrees in F, 6400 hz, 1.0 Ma current, lead R enable.
thanks once again. any extra hints such as this one is welcomed.
I finally have determined the RTD that I will be useing is the 100 ohm platinum (385). I will be moitoring water temperature in a closed loop.
it is a small loop with only a hundred or so gallons of water.
What would be the best filter frequency and excitation for this probe and application.
